MF-35, hydraulics, slow leak?
Chuck, WA
05-07-2002 09:27:55
I have a frame called a carry-all that looks a little like a fork lift that attaches to the 3-point. While using it to carry lumber for my new barn, I would park, turn the tractor off with it in the up position, and pretty soon it would drift down. Is this normal? I got to where I had to leave it running to keep it up, but since the exhaust runs out the back rather than up, it gets a little noxious working back there with it running. If it's a leaking hydraulic valve, how do I fix it?
kjm
05-30-2002 16:51:14
 Re: MF-35, hydraulics, slow leak? in reply to Chuck, WA, 05-07-2002 09:27:55
MF will leak down when the moter is off.
tortmort
05-07-2002 14:19:37
Not normal. It sounds like the 3 point piston leaking. Can check by removing side plate and use mirror to see if fluid is leaking when 3 point is in up position with load. Big Dean is the one to check with.
