135 MF
Charles W. Stor
05-07-2002 19:00:40
Pick up a 135 MF this afternoon, actually pick it up for my daughter, it belonged to her grandfather. He was tragically killed when he fell off this tractor, disc were hooked up and in down position, need I say more. She ask me, if I would fix it up, and that is exactly what I plan to do. Engine was rebuilt 3 years ago by a reputable head and block shop a couple of months before the accident. Tractor has been used very little in the past 3 years since that time. At that time tractor ran perfectly.
I look forward to working on this project, I also look forward to getting to know all of you.
I will be the first to admit I have never had any dealings with a MF, so bear with me.
I will start on this project tomorrow evening, not going to be in any big hurry. The main problems looks to be cosmetics, although, I have not heard this tractor run in a couple of years.
smokey
05-08-2002 04:49:12
 Re: 135 MF in reply to Charles W. Story, 05-07-2002 19:00:40
You have the right machine. If it has been left outside change the trans oil and make sure you use the correct type of oil. When its empty of oil you can clean the hydraulic filter as well. Check the fuel filters for water as diesel will absorb water from the atmosphere. - probably teaching you to suck eggs. Any queries check big Dean Austins site. He is the MF guru. Parts for the MF135 are readily available - in Australia I use Bareco - they have a good web site describing many of the parts on a MF135. Their parts are generic and not OEM but of reasonable quality. Similar importers operate in the USA.
