44 STEERING GEAR BOX
TONY
05-07-2002 20:40:19
I AM LOOKING TO BUY A WIDE FRONT FOR MY MH 44 RC I WAS TOLD TO GO FROM A NARROW TO A WIDE FRONT I ALSO HAVE TO CHANGE GEAR BOXES THEY TURN DIFFRENT DIRECTIONS IS THIS TRUE CAUSE THE WIDE FRONT I CAN GET DOESNT HAVE A GEAR BOX
Michael
05-08-2002 10:12:59
 Re: 44 STEERING GEAR BOX in reply to TONY, 05-07-2002 20:40:19
Tony, You were told correct. On the tubular adjustable
wide fronts(5,I believe), the box is the same part
number but the shaft worm varies, as some tie rods were forward of the box, others behind. This
reverses the direction. The box is probably missing on the WFE, since these wear parts are near impossible to locate in complete set. If you can not buy the WFE w/out the box, for short
money, why search a year for a pricey shaft worm?
Good luck.
Anthony
05-08-2002 10:48:22
 Re: Re: 44 STEERING GEAR BOX in reply to Michael, 05-08-2002 10:12:59
the wide front can be bought for about 250.00 will it be a big problem to find the gear box also is there any times were you dont have to change the gear box and you can use your old one
Michael
05-08-2002 11:07:20
 Re: Re: Re: 44 STEERING GEAR BOX in reply to Anthony , 05-08-2002 10:48:22
Tony,
Yes, but to know, I would need the casting number
on the support housing, which has the six 5/8"
bolts, securing it to the front of the U-frame.
ANTHONY
05-09-2002 17:47:41
 Re: Re: Re: Re: 44 STEERING GEAR BOX in reply to Michael, 05-08-2002 11:07:20
MICHALE THE CASTING #IS 764143M1 THE TIE RODS ARE ON THE BACK SIDE OF THE AXLE AND THE AXLE MOUNTS IN FRONT OF THE GEAR BOX
Michael
05-10-2002 16:31:14
 Re: Re: Re: Re: Re: 44 STEERING GEAR BOX in reply to ANTHONY, 05-09-2002 17:47:41
Anthony,
I don't show that casting # indexed in M-H. Part
#'s one above and one below, but not the support
assemblies. Early: 762142M91 Late: 764151M91.
This would include 44 Tubular adjustable axles
from '49-'54. Also, checked the Specials, no go.
All 44 wides have tie rod spindle arm behind, it's
where they attach to the steering box that counts.
Perhaps that is a 33 part #. With no box, big $$$,
best to pass. Good luck on a complete assembly.
