MF-135
Andy
05-08-2002 14:43:20
Im going to look at a massey 135 this weekend.what are the strong points and the weak points?what should i look for?it is a gas model.thank you,Andy
smokey
05-09-2002 23:54:56
 Re: MF-135 in reply to Andy, 05-08-2002 14:43:20
Normal tractor stuff - has it neen kept under cover or is it full of water in places that it should not be. Stay away from multipower units. - They have an extra "Auto" type speed change giving twice as many gears and are a problem to fix when broken. Tyres are expensive. ROPS - has it one? Check the Hydraulics carefully. PTO will probably be a problem engaging but is easy to fix by a 2 stage clutch adjustment. - This may give you room to haggle. Most parts for these tractors are readily available.
