MH 44 with a tink tink tink tink
Chris Brown
05-20-2002 19:39:02
I have a 44 with the cont 277 engine.It's supposed to have just been overhauled including pistons and sleeves.What type of sleeves does this engine have,its got a tink tink tink sort of noise for about 30 to 60 secs when started cold sometimes,not always.I worked on a M farmall that had a similar noise ,it turned out to be jumping sleeve.
any suggestions
Bruce Colbourne
05-21-2002 20:51:16
 Re: MH 44 with a tink tink tink tink in reply to Chris Brown, 05-20-2002 19:39:02
Hi Chris The continental H-277 engine's have wet sleeve's.It is possible one is not shimed properly or you could have a coneecting rod pin with too much clearance.Hope this helps you.Bruce
Chris Brown
05-23-2002 19:17:12
 Re: Re: MH 44 with a tink tink tink tink in reply to Bruce Colbourne, 05-21-2002 20:51:16
this noise isn't always there.usually a loose ,wet sleeve will start leaking water in the oil after a while,right.I put about 8 hours running ,and it didn't change.I guess I'll tear it down the next rainy day and have a look.I don't mind a noise or two as long as I know what it is. Do you know where I could get a new or rebuilt hydraulic pump for this tractor?
thanks
