What MF Tractors would you recommend?
bnixon
05-21-2002 10:55:09
I am in the market for a used 1960-present diesel tractor on a relatively light chassis. In the size range of a large compact or a small utility tractor. With between 35-45HP. Would like it to be able to handle a loader/box blade/6ft brushhog/and 6ft 3pt finish mower. It will need to have a live or independent PTO and I would prefer not to have to use an extenal pump for the loader. Would like to be able to run the 3pt and loader at the same time. I can only spend about $9,000. What MF models would you recommend that would fit this description and be a machine that would last.
Thanks for the input,
Brandon
Mike C.
05-28-2002 11:23:38
 Re: What MF Tractors would you recommend? in reply to bnixon, 05-21-2002 10:55:09
Brandon,
Sounds to me that you might think about investigating the Industrial line. Early 60's include the MF 203 and MF 205 in diesel. They have a heavier front end for use with the loader than the MF 35 and still have the 3pt with live pto. Other than that, pretty much same tractor as MF 35.
I got mine (gas version) MF 202 w/loader and backhoe in working condition for $3,000.
kjm
05-22-2002 06:50:14
Sounds like you need to look at 165,175 or the 65,75 models. My faveriot would be a 135d small, good power, light wt. easy to work on . abought 5500.00 loaders go for 1000.00 (used) good luck
Chuck, WA
05-22-2002 06:50:05
I'm with Darren on a MF 35 Deluxe - and like him, it's probably because I have one. I bought it as my first tractor this spring so am not an expert, but sounds like all you want to do is well within its range. It's 38 hp I believe - Perkins diesel. Mine is a 1964, has a rebuilt engine and is partially restored with excellent rubber, and around here (south-central Washington state), even with no implements, was a good buy at $4250, even though that's probably high in some parts of the country. Man, if I'd been able to spend $9000, I could even have afforded the implements that I'm now borrowing from a generous friend.
As I looked around, I happened onto a Ford - don't know the model, but guessing it was in the same size/hp range - that was only about 5 years old and had fairly light use, with most of the implements you want (don't recall if it had a loader) and the guy wanted $13,500 for it. That's not saying much with so little information, but with $9000, I'd guess you shouldn't have any trouble finding something that will do all you want to do.
bob
05-21-2002 19:47:26
I think a MF 50 fills the bill except at about half the price. $4500 should buy exactly what you describe.
Don
05-21-2002 19:12:49
I agree with mike with the question you're asking is a pretty tough one. I have a 165 that had an external hyd. pump for the loader, live pto, and ran about 52 hp. With no additional weights on the front or fluid in the tires, it doesn't weight too much either, but with a loader you should atleast have some counter weight on the back for heavy loads.
Don
Michael
05-21-2002 17:33:16
Brandon,
You have a tough question there. By 1960, most tractor companies were throwing their R&D funds
into 80 HP & up tractors. Small diesels were
somewhat overlooked, importing by the late 60's.
A small tractor, durable, with a loader, few. At
$9K, you should follow the money to higher HP. Since New Holland has deep pockets, they should
back Fords for decades. A 6600/6610 is 70 HP,
ran strong, should price into your budget. It's
only an opinion. Good Luck.
Michael
05-22-2002 09:56:55
 Re: Re: What MF Tractors would you recommend? in reply to Michael, 05-21-2002 17:33:16
You mentioned running a loader, don't expect to
handle much besides snow, small tractors perform
more like toys in bucket work. Check out the marginal 3 point on a 65, or the front axle on
any MF below the 180. You are looking at high
maintenance models, with a loader attached. If
no frame, or stress plates, forget a loader. A
nice idea: small tractor, variety of equipment,
but look elsewhere for a superior quality tractor.
Good luck.
kb
05-22-2002 06:47:47
Physically a MF 165 or 65 is not that much different than the 231S you mentioned.
bnixon
05-22-2002 05:02:35
I just really can not use that large of tractor. This is for a 5 acre place. One of the new Compact Tractors would be perfect but I can not afford to pay $20,000 for a tractor so I was wanting to see what you all would recommend in an older model. I need something in a frame size of a MF231S or MF140. I hope this might help in narrowing down the selection.
Thanks again for all of the feedback,
Brandon
darren
05-21-2002 10:58:45
by mf you mean Massey Ferguson not Motha****ker??
i would recommend a to35 deluxe, but thats just because we have one!!!
