MF1150 HYD Question
Bob
05-22-2002 18:54:08
I just purchased a 1150 with HYD. problems.Pulled the charging pump and took it to a MF dealer. It was OK. The radial pump was shot. Got a used one from a yard. They pulled it part and said everything was OK. It was off an 1130. Also checked the priority valve under the dash for junk. It was clean. I am going take the radial pump back out tomorrow and take it to the dealer and have them check it out. Any other suggestions what it might be. No brakes, no steering, no three point or remotes. The PTO does work. Thanks Bob
Drill
05-22-2002 20:51:23
 Re: MF1150 HYD Question in reply to Bob, 05-22-2002 18:54:08
Did you check the pressure on the charging pump? If you had it out and reinstalled the pressure setting might have gotten changed. you need a manual and a gauge to check the pressure, it's under the floor panel, on the same plate the charging pump bolts onto. Did you fill the pump with oil before installing, might not pick up prime otherwise. I had a 1135 with hydraulic problems, real headache, finally sold it. Drill
