MF Z134 timing mark location
cgs0409
05-23-2002 10:12:48
I've got a blown headgasket on my 62 MF35 with the Z134 engine. Before I pull the head off I want to verify the location of the timing marks...but I can't for the life of me find them. Anyone out there have a clue on the marks location and what position the engine needs to be in when setting valve clearances?
Gordon-(TN)
05-24-2002 01:53:06
 Re: MF Z134 timing mark location in reply to cgs0409, 05-23-2002 10:12:48
if you can't find the timing mark, pull the #1 plug out, put your thumb in ihe hole, turn the motor with starter a little at a thime until you feel it blow, stop,put a drinking straw in the hole, turn the motor by hand with one hand on the straw if the straw goes down,stop, turn in the other diriction until the piston gets to top of stroke at this point you can make your mark, it is at t.d.c put the rockerarms back on like they came off then adjust rockers after starting engine .016 is close e&i i don't have the exact setting handy hope this helps Gordon-(TN)
