Massey Ferguson 65 info.
Bill Anderson
05-26-2002 08:49:45
I recently restored a MF 65 tractor with a gasoline engine, serial number SGM 650935. I was wondering if anyone out there could give me some information about this tractor, such as where and when it was made, where it was originally sold and by what dealer, etc. Thanks very much.
Bill Anderson
Joseph Sutton
12-17-2003 15:52:49
 Re: Massey Ferguson 65 info. in reply to Bill Anderson, 05-26-2002 08:49:45
Some of the information you wanted will be hard to get, if it is possible. But I can tell you this about the tractor in question.
It is a 1958 model
It is called a low clearance model
It is a gasoline tractor
And is has a dual clutch, with the standard transmission.
To find out the factory where this machine was built, you need the transmission serial number. The first letter in that will be the code for which plant it was made. The second letter will be for the year, the 3rd part will be the number serial number, the 4th letter will be axle type, and the 5th and last letter will be the modification. This will be on the transmission. I hope that this will be of some help to you.
