Hydr Cylinder
Plugging off down pressure?
BlueLite
05-28-2002 12:18:15
I have the double acting cylinder with the down pressure for my 3PH. The cylinder is under the seat. I find the down pressure a real problem for plow draft and snowblowing. Is there a way I can plug off and simply have a controlled drop on the down lever instead of pressure.
Thanks guys.
Don
05-28-2002 20:01:29
 Re: Hydr Cylinder - Plugging off down pressure? in reply to BlueLite, 05-28-2002 12:18:15
Hate to sound rude, but, WHAT KIND OF TRACTOR IS IT? In order for us to help, we need to know a little bit more about what kind of tractor you have.
Don
BlueLite
05-29-2002 06:45:32
 Re: Re: Hydr Cylinder - Plugging off down pressure? in reply to Don, 05-28-2002 20:01:29
It's a MH30.
The cylinder is a proprietary one that MH
sold as an add on for farmers who wanted 3PH.
steve
05-31-2002 08:47:24
 Re: Re: Re: Hydr Cylinder - Plugging off down pressure? in reply to BlueLite, 05-29-2002 06:45:32
if it is the same as a 22 there is a bolt or pin you remove on the rockshaft below the cylinder mounting to make it free floating
kjm
05-30-2002 16:46:10
I think you will have to change your control valve to one with a float. I think that would be the easyst.
