Perkins A-203
Brian Bell
06-06-2002 05:35:56
Can anyone tell me the bore and stroke of this engine. Mine is in a restored mf 65.Anyone happen to know gross and net hp? Manual says 50 pto hp.Also anyone know bore and sroke of 236 perkins?
Jack in NB
06-06-2002 15:27:32
 Re: Perkins A-203 in reply to Brian Bell, 06-06-2002 05:35:56
Hello Brian -
The 203 is about 50 hp., depending on which books you read. 3.6" bore, 5.0" stroke.
The 236 bore is 3.877". The stroke is probably 5" - I have no spec on it - but the math says the 236 (cu. in. displacement) is exactly proportional to the larger bore/piston area with no change in stroke, when compared with the 203 cu.in.
Hope this helps.
