Lack of hydraulic pressure 44 sp
Chris Brown
06-06-2002 16:35:35
Can anyone tell me how much pressure the timing gear driven pump is supposed to make on a 44 special? thanks
Michael
06-08-2002 15:45:04
 Re: lack of hydraulic pressure 44 sp in reply to Chris Brown, 06-06-2002 16:35:35
Chris,
Checking at the relief valve, with a 2000 PSI
gage,at the port for the pull behind cylinder.
Run engine to normal hyd. temp,disconnect follow
up linkage,hold control lever until relief valve
opens(buzzing sound). Gage should read 1350-1500
PSI for Hitch-All models, 1200-1275 other Specials
If low, repacing the relief valve cartridge in the
manifold may correct,otherwise, faulty pump.
Good luck.
Chris Brown
06-08-2002 17:29:55
 Re: Re: lack of hydraulic pressure 44 sp in reply to Michael, 06-08-2002 15:45:04
Pump is bad! disconnected the pump pressure line and Teed in a 3500 psi gauge ,used a steel ball valve in the other side of the tee ,slowly raised the pressure till gauge was closed and only had 500 psi.This was after I went all through the control valve to no avail.the original pump was no good and I bought this one over the internet.Almost disgusted ,if the engine did'nt run so good it'd be scrap by now. thanks for the reply
Chris Brown
06-08-2002 17:29:25
