TO30 overheat problem
Andrew Vaske
06-12-2002 08:20:35
My 30 recently started to miss very slightly and stutter when I take off- even in 1st gear. Now, I can only work it for a very short time before it overheats. Am I looking at a blown head gasket? Honestly haven't checked the oil for water yet.
If I need to replace the head gasket can anyone recommend the best rebuild kit out there. I had planned a total rebuild, just wasn't going to do it this summer but I may as well if I am going to tear it down for a head gasket anyway...
ANdrew
H.T.Hertz
06-12-2002 12:46:24
 Re: TO30 overheat problem in reply to Andrew Vaske, 06-12-2002 08:20:35
Have you checked your ignition timing and gas/air mixture?
Both may give the symptoms mentioned.
Too lean mixture or too early ignition will surely overheat engine and make it cough.
Henning
H.T.Hertz
06-12-2002 12:45:57
Henning
