Massey 35 gas...dies shortly after starting
bob
06-12-2002 08:20:46
I checked gas line/bulb/screen and carb...all seems tight and are clean , distributor& button seem ok, some wear...engine dies about 30 sec after starting cold, and sooner after it ran for 30 seconds acts like it runs out of gas, but thats not it, almost sure...any help on this one out there??
J.A.P.
06-30-2002 17:50:01
 Re: massey 35 gas...dies shortly after starting in reply to bob, 06-12-2002 08:20:46
Buy a rebuild kit for the carborator.It sounds like the needle and seats are sticking.Ijust had the same problem with a 64 MF35,Runs like a dream now.
ALAN
06-12-2002 22:04:45
Have you taken the fuel line off at the carb & checked flow? should be a steady flow... if not a likely culprit is the little stem screen in the gas tank. Another is the little needle valve in the carb. I also have the I & T for that tractor... if you need specifics let me know. - ALAN
