180 Engine Oil Leak
Lance
06-12-2002 13:46:16
I have a 180 Diesel.. oil leaks between head and block.. also.. if it idles long enough it will force it out exhaust.. am I in need of an overhaul.. it has about 4700 hours on it...
Drill
06-12-2002 17:44:03
 Re: 180 Engine Oil Leak in reply to Lance, 06-12-2002 13:46:16
The leak between the block and head is probably unburned deisel fuel. Sounds like you have a leaking head gasket and one cylinder not firing and bore filling with raw fuel. Its the same stuff thats being pushed out the exhaust pipe. You need to do a compression check and probably change the head gasket. A engine overhaul may not be needed, but if you have to take the head off check the exhaust valve seats, they usually need changing. I have a 180 and am very happy with it. Drill
Drill
06-12-2002 17:39:01
Drill
06-12-2002 17:33:57
