TO30 Overheat again
Andrew Vaske
06-18-2002 05:51:26
My 30 will only run for about 5 to 10 minutes under any load before it blows out the top of the radiator. Posted once before and was told that lean fuel mixture or timing might be the cause- engine also had a slight cough. Have never messed with either fuel or timing so I really don't think that it could be the problem- alway ran fine before.
Now engine seems to run smooth yet it will still overheat. Checked to see that the thermostat wasn't sticking and found that it didn't have one installed. Again, always ran fine without overheating before so I don't think that can be the problem either.
What else can I look for? How do you check the fuel mixture?
Thanks
Andrew
ErnieD
06-21-2002 15:04:46
 Re: TO30 Overheat again in reply to Andrew Vaske, 06-18-2002 05:51:26
Any water/coolant in the oil? These motors warp the cylinder head easily.
