Serial No. problem
Brian Jones
06-25-2002 12:15:15
Could anybody assist as the serial No. plate has been removed from tractor.
Is there away of working the serial No. from markings on various parts on the tractor.
David B
06-25-2002 14:46:33
 Re: serial No. problem in reply to Brian Jones, 06-25-2002 12:15:15
Depends on what kind of tractor it is. Massey Harris has the model and serial number stamped on the transmission case top right side between the trans top cover and the rear end top cover. I don't know about Massey Ferguson's.
Alberta Mike
06-25-2002 20:18:47
 Re: Re: serial No. problem in reply to David B, 06-25-2002 14:46:33
I think it is on the top left if I remember, not the top right. Probably filled with a lot of crud and paint too.
David B
06-27-2002 20:09:39
 Re: Re: Re: serial No. problem in reply to Alberta Mike, 06-25-2002 20:18:47
You are right. The number is stamped on the left side of the case. I knew that, sorry
