231s compared to 135
wondering
06-27-2002 10:05:32
what is the differences between these 2 tractors? both are diesels with same engine. is a new 231s worth having? is it the same quaility as older 135?
Tommy in OH
07-14-2002 08:53:52
 Re: 231s compared to 135 in reply to wondering, 06-27-2002 10:05:32
I was hoping someone more knowledgeable would post a reply. But, here's my two-cents' worht.
I own a '95 MF-231S, made under license by Ursus of Poland. Newer models sold by MF are built in Turkey. I bought my MF-231S last year and have used it primarily for mowing. My tractor had 139 hours on it and I paid $7000. It came with remote hydraulics, the only extra.
These tractors are imported by MF as a low-cost, no-frills utility tractor. The Polish and Turkish made tractors are used in countries where frills are not affordable. The MF-231 is little changed from the MF-135. This means they still basically employ 1970's technology. They are crude by today's US standards. The sliding gear transmission is balky, and you have to take your time shifting. These are small agricultural tractors, not Japanese-derived compact "estate" tractors.
If you want a tough, inexpensive, simple tractor primarily to mow with, I think you'll be happy with the MF-231. The Perkins diesel engine has been around forever, and is considered to be very durable. I put mine in third gear, set the throttle on the PTO setting, and pretty much leave it there for long periods of time as I mow. It's great for this use. A replacement seat with spring suspension (if you buy one with the original pan seat) is pretty much a must-have. I consider the MF-231 to be a good choice, if you can live with its limitations.
Randy
06-28-2002 14:53:36
Well I don't know if they're exactly the same, but the 231s is made in Turkey by Uzel. Park them side by each and you'll see a lot of parts probably would swap. The quality should be high if Massey wants to keep business.
steve
11-18-2003 16:12:22
 Re: Re: 231s compared to 135 in reply to Randy, 06-28-2002 14:53:36
I own one of each. The 135 diesel is a 38HP 3-152 Perkins. The 231S is a 45HP 3-167 Perkins.
If you use anything PTO driven, you will notice the difference. Also, the 231S has about 1200 more pounds in weight with water ballasted rear
tires.GREAT tractors!
John in OH
05-29-2005 04:31:02
 Re: Re: Re: 231s compared to 135 in reply to steve, 11-18-2003 16:12:22
I just purchased a used 2002 MF 231S. What can you tell me about them? The one that I purchased had 101 hours and I bought it for $8000 delivered. I considered it to be a steal for the price.
Thanks
John
