44 Crank shaft installation
Gary
06-30-2002 19:15:30
I have a 44 that has the entire block in pieces. I cannot figure out exactly how to put it together with the crank being correctly installed. There are two thrust washers, shims, etc. Can any one out there in Massey Land tell me step by step how to do this right?
Thanks
bob
07-03-2002 07:41:55
 Re: 44 Crank shaft installation in reply to Gary, 06-30-2002 19:15:30
Gary has your 444 set out in weather for some time I just overhauled mine and had it in garage and water was leaking out pto. Knew they have problems with water getting in and drained out about 10 gals Might pay to check yopurs . In special had it freeze in winter and had to build fire to get to move bob
Professor Proper
07-01-2002 09:51:31
Gary,
This step-by-step would be tedious and risky for
a correct assembly. Best advice would be to get
a parts list and shop manual to review H260's. We can answer a question, but your posting would require writing a chapter. Good luck.
