MH 444D Live PTO??
-Ryan-
07-05-2002 12:21:20
Does the MH 444D have a live PTO? I am interested in purchasing a 444D Standard and I am planning to use it for haying and snow removal along with some loader work. Also, is the PTO too high for most machines? Can the hydraulic pump handle a front end loader? Thanks. -Ryan- British Columbia, Canada.
444LP in Minnesota
07-07-2002 19:49:28
 Re: MH 444D Live PTO?? in reply to -Ryan-, 07-05-2002 12:21:20
The live PTO was an option. My 444 does not have the live PTO but has power steering a factory three point hitch. The hydraulic system is more than adequate for a loader. Mine will pickup my Bridgeport milling machine. The mill weighs 3200 lbs. You will need fluid and wheel weights however.
Good Luck.
Bill Shaver
07-06-2002 00:39:54
I recently bought a similar tractor mine has live pto & hydraulics, the pto shaft is lower on the rear chasis than the 44 or 44 super. For what reasons??? Its the way they were bulit. Mine came from Yorkton Saskatchewan, it has all the tin, even the pieces under the seat & the forward hatch to give you acces to the hydraulic tank & radiator. Over all a good puller, lots of power, & I use it with my international harvester model 82 combine. It does me justice, however am looking for a 3 point linkage to bolt on the rear. It has the same rear end chasis as the 444 row crop. anyhow good luck, hope you restore it to original shape, its a real nice tractor overall & styling you dont see anywhere else. As for front end loader I believe the hydraulics in those days were limited in capacity, but I do remember seeing some of these tractors with loaders on them.
Bill.
marlowe
07-05-2002 17:20:19
should have live pto. the pto is low on 444. pump will work for a loader just a little slow.
-Ryan-
07-05-2002 20:32:55
 Re: Re: MH 444D Live PTO?? in reply to marlowe, 07-05-2002 17:20:19
Thanks Marlowe
