TEA 20 Starter
Bian Messenger
07-05-2002 18:17:39
Can anyone help ? When I push the gear lever forward to engage the starter, nothing happens. This model does NOT have the safety heel switch. I now have to start it using a screwdriver across the starter solenoid.
Ralph
07-07-2002 04:13:14
 Re: TEA 20 Starter in reply to Bian Messenger, 07-05-2002 18:17:39
Had the same problem easy fixed.under the battery on top of trans case.Is the solinoid where you remove the top where your wiring points are. under this is a brass ignition button clean this and the two bush's so you have a clean conection.
It should turn now if they were dirty and corroded.
Ralph. Sth Aust.Australia
Peter, U.K.
07-06-2002 00:46:45
Brian, I'm a bit puzzled by your question. You say that your TEA does not have the heel starter switch - it shouldnt have, as far as I'm aware the heel switch was only fitted to the TEF (diesel) model. You should have a solenoid mounted beneath the battery holder on top of the bellhousing this is connected internally to the gear lever. First try checking all the electrical connections - are they tight and clean. If these are OK I would then replace the solenoid.
Hope this helps, good luck,
Peter.
