165 Hydraulic bleeding and location of oil fill
MikeP
07-06-2002 06:12:33
I have a 165 that has a front loader,which looks like it was "original" to the tractor. I blew two hoses and replaced them. Now the bucket will not lift the back implement does, so I think the pump is working. Where do I bleed the front Hydraulics?
Also, were is the oil fill for the engine?
peltsi
07-07-2002 01:18:04
 Re: 165 Hydraulic bleeding and location of oil fill in reply to MikeP, 07-06-2002 06:12:33
i assume the front loader is operated from the main pump, right? In that case, it uses the transmissions oil, and the fill cap is next to the shift lever.(under some plate, at least on my mf168) I don't know how to bleed the front loader, as i don't have one...
Engine's oil fill is in the injector pump.
