MH 30 or 33 ?
Bill MacPherson
07-13-2002 18:56:35
I've got a "vintage MH" tractor . decals say it's a 30 , but it has power lift cylinder and a side mounted hydraulic pump. Is it a 30 or perhaps a 33? ----Bill
Alberta Mike
07-14-2002 07:17:14
 Re: MH 30 or 33 ? in reply to Bill MacPherson, 07-13-2002 18:56:35
Easiest way to tell is the engine difference. The model 30 used a flathead 4-cylinder while the 33 had an overhead valve 4 cylinder. The 30 evolved from the model 101 Junior. Then the 30 evolved into the model 33 which in turn became the model 333. The biggest difference was the jump between the 30 and the 33. Do you have a serial number that you could post so you'd know the year of manufacture?
BigMac
07-14-2002 01:44:32
My 30 had a side mounted pump, before the engine was junked, and has a lift cylinder in the back for a three point hitch. So, it probably is a 30.
