135 Steering Problem
Rodney
07-13-2002 20:50:05
I have a Massey 135 diesel that has manual steering. The steering wheel will turn but the tires will only turn to the right but not much.I just bought the tractor so any advice would be a big help! Thanks
Bill MacPherson
07-14-2002 04:31:42
 Re: 135 Steering Problem in reply to Rodney, 07-13-2002 20:50:05
First disconnect your steering rods and check your front spindles for binding . I have seen them so tight that the steering wheel won't turn them . If they turn free and wheel still won't turn you got to take steering box apart. GOOD LUCK---Bill
mhmalcolm
07-13-2002 22:54:39
Most likely, water has gotten into the steering gearcase and has rusted the parts, causing the binding. Ran into this on a Massey 65. You will have to completely disassemble the gearcase, clean
all the parts, and replace what ever is necessary.
Good Luck!
