135, grader drops like a rock, is there a bleed method?.
Joe Kreft in N.
07-15-2002 06:33:54
Hi all,
Bought a '65 135 (gas) last year with loader and heavy grader box to equalize the weight. Before any real chance to use it the hydraulics stopped lifting the grader. Info from this board told me to clean the filter and replace fluid. Did both. Now, it lifts but when I push the clutch it drops. Also, when I hold it at any given level I can feel a slight pumping/pulsating as if the hydraulic pump is struggling. And when I push both (draft and elevate)levers to go down, the thing does almost a dead fall.. Any suggestions? Seems like the hydaraulics need to be bled off. If not, know any good mechanics in Northern Michigan?
Thanks, Joe
P.S. Loader and PTO work perfectly..
prune
07-15-2002 15:15:20
 Re: 135, grader drops like a rock, is there a bleed method?. in reply to Joe Kreft in N. Mich, 07-15-2002 06:33:54
Either an 'o' ring's gone or you've got a cracked cylinder
