Firing sequence
Bryan Robinson
07-30-2002 15:21:28
Hello All,
I need to make sure that Ihave the correct sequence for spark plug firing for a '69 MF 135. The block has the firing sequence as 1-3-4-2 stamped on it. Now, which is #1 on the distributor cap? And how does the sequence go, CW, CCW, etc.? This is a friend's tractor and I am trying to get it running correctly. Thanks for the help. Please reply to my email.
Bryan
Tim
08-09-2002 20:16:42
 Re: Firing sequence in reply to Bryan Robinson, 07-30-2002 15:21:28
Crank the engine until you get compression on number 1 cylinder. Lift the distributor cap, and run the wire to the post the rotor is on. After that, then follow turn the engine to the next rotor position for the next cylinder.
Tim (TX)
07-31-2002 17:28:24
Hello Bryan, I have a MF135 diesel. My manual covers gas models. The firing order you listed is correct (1-3-4-2), but my manual does not have anymore info about it. I'm sure someone else on this board will know which plug is #1 at the distributor cap, etc...
Sorry I cant help you more,
Tim
