12 volt conversion TEA 20 Ferguson
Greg Chalmers
03-29-1998 11:56:17
I want to change from 6v to 12v. I understand Chevy
parts can be used. Will anyone please advise the best procedure from start to finish?
Thanks in advance, Greg.
Tad McGrew
05-04-1998 19:05:58
 Re: 12 volt conversion TEA 20 Ferguson in reply to Greg Chalmers, 03-29-1998 11:56:17
YES I used a GM alternator w/built in regulator. You will need to put in a resistor to protect the points. I rewired the entire tractor using the diagram in the I-T Shop Manual. If you use the old harness sometimes the lternator will send current through the charging system even after the key is cut off and it will keep on running. An easy problem to fix with a diode at the alternator, but it can be quite surprising the first time it happens. Good luck and buy the manual, the best $20 I spent for me and my tractor.
Tad McGrew
Bill Brox
03-30-1998 07:06:23
Why not use the original Lucas parts, they are still available for 12 volts as well as the old 6 volts. At least as far as I know.
Will keep the tractor more original if you plan to take it to exhibitions.
Bill
Andy Marchese
03-24-2000 19:31:12
 Wide front for MH 22 in reply to Greg Chalmers, 03-29-1998 11:56:17
