101jr whats the extra linkage rod for??
Gary
08-06-2002 05:35:02
the linkage from the govenor to the transmission is for what? does this rod kick the tractor out of gear? my operators manual does not help!
Alberta Mike
08-06-2002 13:29:10
 Re: 101jr whats the extra linkage rod for?? in reply to Gary, 08-06-2002 05:35:02
Yes, the post below is correct, it was really a "no cost" feature that Massey used a lot in their advertising, etc. You'll notice on your shift platform there is a "B" which should be shifted into when doing belt work. There is a little housing at the front (carb side) of your transmission that holds the shifting rods or rails. On the twinpower tractors, there is a little arm that sticks out the side of that housing. When the tractor is shifted into "B" or into 4th gear (for road travelling), that little arm should move (can't remember which direction) and it moves the rod which in turn somehow causes the regular governor RPM limits to be bypassed. These would be the limits when doing drawbar work in 1st, 2nd, 3rd, or doing something while in neutral. Thus, the higher RPM is obtainable for the belt work and higher speed driving.
LH
08-06-2002 09:09:12
That's the "Twin Power" rod which is basically a disconnect to the governor when you shift into the belt drive gear, allowing the tractor to achieve higher rpms for old belt drive equipment. If it's working correctly you should only be able to move your throttle through the normal range area when the tractor is in one of the numbered gears, but can move it on down if it's shifted into the belt drive gear.
Gary
08-07-2002 04:58:44
 Re: Re: 101jr whats the extra linkage rod for?? in reply to LH, 08-06-2002 09:09:12
you know makes great since. I move the linkage as if were shifted into position and it blocks movement of the governor travel! thanks fellas
