PTO fill point?
Ben Moore
08-14-2002 14:34:08
I have a Harry Fergueson TO20. either a 1950 or 1951 model. I checked the PTO dipstick on the right hand side of the case (sitting in the seat as you would while driving) right below the seat. It showed low. Could not determine where to fill the case. Was told that a hydraulic oil #303 is what I need to use. Is this correct and where do you fill the case? Any help would be greatly appreciated. Thanks, Ben Moore
smokey1
08-15-2002 02:34:54
 Re: PTO fill point? in reply to Ben Moore, 08-14-2002 14:34:08
I think it is at the gearbox bear the steering column. Same oil is used in gear box. Make sure you get and use the right oil as some multigrade you beaut oils can affect your hydraulics etc.
