1959 Massy-Ferguson
Mark Shelton
08-21-2002 15:27:35
I am trying to find out how to set the timing and where the tick mark is for doing this.
Mark Shelton
08-23-2002 14:17:47
 Re: 1959 Massy-Ferguson in reply to Mark Shelton, 08-21-2002 15:27:35
Thanks for the help Norm it was just as you said.It is starting and running just fine now.
Norm
08-21-2002 18:04:43
Hi Mark, Could you elaborate further on which model you're inquiring about? If it's a TO 35, it should be set at 6 deg BTDC. You'll find the marks on flywheel just in front of clutch. Look for a rubber cap looking towards the back on the right hand side of the bell housing.I had to dab the mark with paint using a Q-tip to use with timing light.
Good Luck
