TO35
Al
08-25-2002 06:07:02
I found this old tractor in a shed on a place I bought. It probably hasn't run in years. How do you determine if it is gas or diesel? Also, what is recommended for getting it running? All parts appear to be in place.
Bob in CA
08-25-2002 11:57:03
 Re: TO35 in reply to Al, 08-25-2002 06:07:02
If it is gas, it will have a carburetor on the right side of the engine. If it is a diesel, it will have an injection pump with injection lines on the left side. First determine the gas or diesel and then that will determine the extent of cleanup prior to starting. Let us know
Bob
Al
08-25-2002 13:19:09
 Re: Re: TO35 in reply to Bob in CA, 08-25-2002 11:57:03
Thanks for the tip.It turns out to be gas.
Tom G (OK)
08-25-2002 11:55:44
A gas engine will have spark-plugs connected to a distributor.
As to getting it running, I remember my grandfather finding an old Indian motorcycle in a shed. He ran kerosene into the spark plug holes and let it sit for about a week, then he cleaned up the plugs, changed the oil and filters, blew out the carburator and sprayed carb cleaner all over it, then he put me to work kicking it for HOURS until it finally started (about 1:00 AM (the neighbors were just thrilled))
First, he'd check for spark by pulling out each plug and laying it against the block. I'd kick, and then he'd look to see if there was a spark on the plug.
There's a starting adjustment for every carburator from which fine adjustments can be made. For the Z-134 engine you screw in the idle air all the way, then open it up about one turn. Then set the main jet to the closed position (not tight!) and open it back up about one and one quarter turn.
Then he'd spray starter fluid into the carb. if the engine ran while spraying the fluid, about a squirt every three seconds, then it was a fuel problem.
Once it's running, set the idle to about 450 to 500 rpm, then open the idle air until it just begins to run smoothly, finally, adjust the main jet to where you can accellerate smoothly.
It's all a matter of checking for spark, fuel, and air.
I have no earthly idea how to get a diesel started. that's why I have a gas model.
TOM
