3 points
Eric Kavanagh
09-08-2002 12:19:13
I brooks the pin for a bar of 3 points, the pin on a right side of axle. I have to change the big cover or i can replace only the pin.
My tractor is a MF-50 1964 serial SGMI5258.
smokey
09-09-2002 23:57:22
 Re: 3 points in reply to Eric Kavanagh, 09-08-2002 12:19:13
Check Bareco Aust website for a parts explosion. Check the size of pin because 2 sizes were used. It is bolted from the inside needing the housing to be removed.
gy3020
09-08-2002 18:43:12
The pin should be able to be replaced. I have a 135 that when I first bought the tractor one pin was loose and they replaced it with another one.
The axle housing will of course have to come off to do it.
