44 massey harris engine
w. angle
09-08-2002 15:13:21
could anyone tell me how big a 260 mh engine can be bored and stroked?
w. angle
09-12-2002 12:40:57
 Re: 44 massey harris engine in reply to w. angle, 09-08-2002 15:13:21
Will a H277 MH head bolt on a 44 H260? Will this help the breathing? Were these heads on a 44 special and a 444?
bigmotors
09-11-2002 04:11:42
I used 1066 IH sleeves/ and 2 inch cont. rods. out of a D-19 AC. Which you have to cut and lengthen. I think their around 7.250 inchs long stock. Been a why'll ago. I have found that real big cu. sometimes is not the answer with a 44. The head sucks!! Your really are limited for air and fuel. My two cents.
Good Luck.
JDBert
09-09-2002 17:20:42
Heres Masseypullers e-mail, he'll be able to help you with the mods to the 260, masseypuller@worldnet.att.net
Heres another address that you'll need to get parts. JLutzke@johnsonville.com
Hope this helps
Wes Ballhagen
09-09-2002 19:20:34
 Re: Re: 44 massey harris engine in reply to JDBert, 09-09-2002 17:20:42
I was wondering where I could get a catalog or a good place to find parts for a 44 Massey Harris. I would particularly interested in a catalog or list of available parts to find the required parts to fix the tractor properly.
Thank you for your time,
Wes
angle
09-09-2002 17:16:14
will a 55 engine fit in a 44 row crop and do they look alike?
JDBert
09-09-2002 17:37:35
 Re: Re: 44 massey harris engine in reply to angle , 09-09-2002 17:16:14
A "55" motor will fit with some mods to the front mount shorten the drive train hookup. But the 55 has a 382 in it and is similar but obviously larger, but if you have the cash you could get something like 700 cubes out of it.
Jeff
09-11-2002 05:24:55
 Re: Re: Re: 44 massey harris engine in reply to JDBert, 09-09-2002 17:37:35
As Don stated, the starter is on the opposite side, which makes for a difficult time connecting to the original gearbox for steering.
don
09-10-2002 04:02:00
the starter on the 55 engine is on the opposite side
Gump
09-09-2002 16:21:30
you can take them to about 550, depends on how long you want them to last. 7.5 stroke is about the max you can get in one that I have found. Want more info, email me.
gump
Don
09-09-2002 04:05:01
504 cid is about the biggest(2 inch stroke,4 5/8 bore) 437 cid with factory rods(1 inch stroke)
I heard of the diesel doing well around 327cid(4" bore x 1" stroke)
w. angle
09-09-2002 16:24:19
 Re: Re: 44 massey harris engine in reply to Don, 09-09-2002 04:05:01
Thanks Don, This is my first effort at a pulling tractor so I need lots of help. What kind of rods, sleeves and pistons would you recomend. How much stroke with out major block work? Thanks
marlowe
09-08-2002 18:47:33
there is a guy that calls him self massey pull out of minneapolis minn. that might be able answer that but i can not find his email address hope he see your post. he was in to pulling a 44. but have not seen a post from him in a long time ??
Masseypuller
09-24-2002 09:50:05
 Re: Re: 44 massey harris engine in reply to marlowe, 09-08-2002 18:47:33
Hey Gang!
I am still here! I just have been HERE for a while! If anyone needs technical assistance with mods to an H260 or other MH, drop me a line! As another guy says: "Mild to WILD", I do it all!
My 590 cubic inch powered 444 is just about ready to roll out of the shop. I have absolutely CURED the airflow problems with the 44 (H260/H277) cylinder head. Expecting a "real" horspower result of 200+ at stock +20%, lets all hope that it will hold together! But more about that later...
Regards,
Masseypuller
masseypuller@att.net
