Ran out of diesel how to prime
chris taylor
09-20-2002 18:43:17
i have a massey 135 it ran out of diesel today i filled it up took out two screws on the carbutretor until diesel shot out of the holes closed them backk up the tractor ran perfect for about ten minutes and died can someone tell me how to properly prime diesel engine
Mike
09-21-2002 18:09:26
 Re: ran out of diesel how to prime in reply to chris taylor, 09-20-2002 18:43:17
If it ran for 10 minutes then died you have
another problem,under normal conditions it should
take less than a minute to bleed it self when
running.Probably should change the fuel filter
while your at it.We just pull ours,shoot a little
starting fluid into the breather,and don't bleed
anything.It will miss for a minute or so,then
run good.
Tim (TX)
09-20-2002 21:23:52
Hello Chris,
Big Dean Austin has some great pictures on a web site that can help. One of them fully describes how to bleed the fuel system on a 135 diesel. He also sells a CD that contains this and MUCH more. Follow the link below to the picture site. When you get it fixed, you can email Big Dean at Daustin62@aol.com and find out about buying his CD. You'll be glad you did! Good luck, Tim.
