135 PERKINS DIESEL
jimbob
09-21-2002 18:36:51
M F 135 OIL HAS POURED DOWN THE LEFT SIDE OF ENGINE CANT TELL WERE IT CAME FROM THE ONLY PLACE THAT I THINK OF IS THE VALVE COVER IS THIER ANY OIL LINES ON THIS SIDE OF THE ENGINE THE OIL HAS RUN DOWN THE ENGINE AND RAN QUICK ANY HELP WOULD BE GREAT IT IS A PERKINS 3 CYL DIESEL
Ricky from NC
10-15-2002 17:36:36
 Re: 135 PERKINS DIESEL in reply to jimbob, 09-21-2002 18:36:51
I just finished rebuilding a MF 35 3 cylinder Perkins Diesel. There is an oil pressure sensing line on the left side of the engine that feeds the oil pressure gauge. A leak some where on this line is possible.. I had an oil leak on my left side..It was the oil filter seal ring...Oil filter is on the left side. It was a pain to get that oil filter seated corectly. That is the only external oiling I remember. If the valve cover is leaking you should feel oil laying around the outside of the fuel injectors which are vertical.
