Strange Massey Ferguson Rear wheel Lug nuts
Allan
09-30-2002 10:03:08
I have 8 wheel lug nuts per tire, that are about 2.5" to 3" long treaded all the way through. When they are screwed down on the stud on a cast wheel there is about .75" to 1" left open on the end with the nut.They slide into the wheels like an insert with the nut on the end.
Is this to accept a dual wheels? Do other studs fit into these?
The locale dealer did not seem to know.
There are separate holes for weights.
I have 16.9 X 28" tires with PAVT rims on Cast centers.
Joe Ferguson
10-02-2002 11:10:33
 Re: Strange Massey Ferguson Rear wheel Lug nuts in reply to Allan, 09-30-2002 10:03:08
Hi Allan
There is another link to dual wheels adaptors
Link
Unfortunately I don't know if it fits on your
tractor.
HTH...good luck
Joe Ferguson
Joe Ferguson
10-01-2002 12:34:10
Hi Allan
Here is a link to some dual wheels adaptor
Link
HTH
Joe Ferguson
Allan
10-01-2002 16:29:55
 Re: Re: Strange Massey Ferguson Rear wheel Lug nuts in reply to Joe Ferguson, 10-01-2002 12:34:10
Thanks Joe that was a big help, now I know what I might be looking for. Do you think it would work on a cast MF wheels ?
Do you know if they are still available to order?
marlowe
09-30-2002 18:38:10
it sounds like you have a set that are used for duals but you also need the spacer that goes over the nut part its about 1.5 in thick and then the wheel and 8 more nuts per side
Allan
10-01-2002 04:59:35
 Re: Re: Strange Massey Ferguson Rear wheel Lug nuts in reply to marlowe, 09-30-2002 18:38:10
Is there a source to get those spacers, or some place I can look them up, to see a picture of them?
Thanks for the info marlowe.
