1947 Massy Harris 22
Chuck George
10-03-2002 17:26:07
I own a 1947 Massy Harris 22 tractor, and plan on donating it to a local charity. I need to find a legitiment price to write off on my taxes. It runs and has a 3 point hitch and a hydraulic system. It is the original 6 volt system. It has good tires. The paint is ratty, but not rusty. It also has a 6 foot blade. Where can I go to establish the proper figure to assign the taxes? Thanks for any help.
Chuck
Ed
10-08-2002 04:22:58
 Re: 1947 Massy Harris 22 in reply to Chuck George, 10-03-2002 17:26:07
Chuck would you please email me a pic of the tractor. Thanks Ed
Alberta Mike
10-04-2002 05:46:42
If the tin oval ID plate is missing then the serial number is also stamped into the machined surface on the top of the transmission/differential housing. Look on the left (clutch side) between the cast shifting platform (where the gearshift is) and the steel plate that covers the differential gears. It will be in there, probably covered with paint so you might have to do a bit of scraping and wire-brushing. Sometimes the numbers are not stamped in too deeply. Underneath the rearend area are the casting date numbers which are cast in. This doesn't tell you the year of manufacture or the serial number, only when the casting was poured but it is a ballpark ID of year.
Chuck
10-04-2002 08:24:44
 Re: Re: 1947 Massy Harris 22 in reply to Alberta Mike, 10-04-2002 05:46:42
Thanks for your reply.
Chuck
Chuck
10-03-2002 17:44:32
I don't seem to be able to find the tractor's serial number. Can anyone tell me where to look? Thanks,
Chuck
scooterhead
10-04-2002 03:18:25
 Re: Re: 1947 Massy Harris 22 in reply to Chuck, 10-03-2002 17:44:32
There should be a oval tag on the frame rail in front of the clutch .
Chuck
10-04-2002 08:22:51
 Re: Re: Re: 1947 Massy Harris 22 in reply to scooterhead, 10-04-2002 03:18:25
Chuck
