101 Jr. weight
Scott (CT)
10-07-2002 06:06:06
Does anyone know the weight of a MH 101Jr? pressed steel 9 bolt wheels, tires not loaded. I got one in the spring, got it running and took it to a fun pull yesterday. I had 1 set of Oliver rear wheel weights on it and outpulled a farmall H w/2 sets of weights. This is not color bashing as I own 3 farmalls myself. If anyone has weighed theirs and could share that with me I would appreciate it. Thanks in advance.
Darrell
10-08-2002 19:18:10
 Re: 101 Jr. weight in reply to Scott (CT), 10-07-2002 06:06:06
my brother has a 1944 101 jr that he pulls in the 3250 lbs and the 3500 lbs class a real strong puller that all the green guys are envy of ,
Kevin M
10-07-2002 18:28:11
Well I don't know the weight on a Jr. model but my MH 101 senior is right on 4000 pounds with me on it. It also has the nine bolt pressed wheel without fluid. Also has all the gears and pto but is somewhat filled in places with bondoe. So yours should weigh less.
Alberta Mike
10-07-2002 17:23:50
I've got a chart here comparing the 101 Jr Row Crop with other tractors in that same class. It says the shipping weight was 3085 pounds, that's with 9-36 rear rubber. In 1941, that tractor sold for $920 so they've kept their value well I guess (Ha). Good luck with your project.
Scott
10-09-2002 05:57:17
 Re: Re: 101 Jr. weight in reply to Alberta Mike, 10-07-2002 17:23:50
Thanks for your help guys. I'm feeling pretty good about my $75 tractor now.
