165 MF
Hassel Ayers
10-07-2002 06:07:09
I was wondering what size turning plow the 165 [gas burner] was rated to pull? I know that it was a 3 plow, but was it 3 - 14s or 3 - 16s? Also what would be the best plow for this tractor,make & model?
Two 16's Tops
10-10-2002 20:53:29
 Re: 165 MF in reply to Hassel Ayers, 10-07-2002 06:07:09
Some people only plow about 4 inches deep. If you put it in the ground about 7 or 8 inches deep, you will be loaded with 2 16" plows in average soil.
José Carlos vieira
05-07-2003 16:58:36
 Re: Re: 165 MF in reply to Two 16's Tops, 10-10-2002 20:53:29
Desejava comprar um Massey Ferguson 165, em estado o mais original possivel se tiverem por favor contastem-me ..obrigado
Dave
10-10-2002 19:59:23
The 165 was rated to pull a 4 bottom 14" plow.We farm in north Missouri and the 4 14" semi mounted was a real load on our clay hills. We now have a 3 16" mounted but only use it to plow the garden.Our 175 was rated a 5 14" but we pulled a 4 16" semi -mounted, it was hard to keep the front end down, have plowed 1/4 mile with the front wheels off ground.Only plowing done in our area is terraces now.
marty g.
10-10-2002 08:50:23
It all depends what type of soil your are plowing, but remember that a gasser is rated at forty some HP. Comparing it to a 180 is a bit harsh, 20 HP difference is alot. And the 180 came on 38 inch tires,"more traction to start with". I know our diesel 165 came on 28 inch tires but I don't know about the gasser. You might want to borrough a plow to see what you can do with your tractor. My opinion is the gasser is good for a 2 furrow.
fred
10-09-2002 18:51:34
It should pull a 3-16. I have a 180 that will pull 4-16's I have a 165 and have used a 3-14 on it and it plays with it
Don_Wi
10-09-2002 19:43:49
 Re: Re: 165 MF in reply to fred, 10-09-2002 18:51:34
Where do you live? My 165 can only handle a 2-14 plow, up here near Green Bay in NE Wisconsin. Once I finally manage to get it shined up it might be better but i dunno.
Big Jim
10-10-2002 14:29:40
 Re: Re: Re: 165 MF in reply to Don_Wi, 10-09-2002 19:43:49
Fred must live in sand country. I also live in northern WI with heavy clay soils. My 165 Diesel is really working with a 2-14 plow on it. You might be able to pull a 3-14 plow in heavy clay, but you'd have to be in low gear to do it.
