Massey with Standard Motor
Al
10-13-2002 18:01:47
I have an old Massey 4cyl.with a split fuel tank.They say it was built in the U.K.It has a motor built by the standard motor company. I have searched every where for parts. It is in running but I could us a water pump,disb. disb cap,points and plug wires.also a manifold
WILL
10-15-2002 17:38:52
 Re: Massey with Standard Motor in reply to Al, 10-13-2002 18:01:47
CHECK WITH HINTON AT JACKSON WHOLESALE 1 800 850 3779 HE IS SOUTH ALABAMA
Damon
10-14-2002 18:41:38
Al,
most of the parts you require are available thru bare-co. They are an Australian company but now supply to the US. Most parts you require can be obtained thru there dealers. Go to there web site for a look. www.bare-co.com
I hope this helps. All parts are TE-20 (UK model- standard engine).
Damon
Peter, U.K.
10-14-2002 01:16:14
Al, Sounds like you have a Ferguson TE. All the parts you need are readily available in the U.K. Where are you located?
AL
10-14-2002 18:05:31
 Re: Re: Massey with Standard Motor in reply to Peter, U.K., 10-14-2002 01:16:14
PETER,
I AM LIVING IN NORTH FLORIDA U.S.A.MY FATHER BOUGHT THIS TRACTOR BACK IN THE EARLY 80S.YOU DO UNDERSTAND THAT I BELIEVE THIS TRACTOR DATES BACK TO THE EARLY 40S,I AM IN NEED AT THIS TIME A MANAFOLD,DISTRUBTOR,ROTOR,PLUG WIRES AND A WATER PUMP. ALTHOUGH I USING THE TRACTOR AS IS JUST KEEPING IT TOGATHER THE BEST I CAN. IF YOU HAVE ANY CONTACTS I WOULD REALLY APPRECIATE IT WHEN I GET BACK HOME THIS WEEKEND I COULD EMAIL SOME PICTURES.
THANKS FOR THE RESPONCE AL
