Y-91 flathead gasket ....copper coat it or not?
Bob LaBrie
10-19-2002 05:38:29
I'm fixing to buckle up my Y-91 flathead and am not sure whether to spray both sides of the gasket with copper coating head gasket spray or install with nothing at all. Also, I plan to use new 3.5" studs and see the orignals are 3/8" 24 pitch thru the head and 3/8" 16 into the block.
Question: Do I use lock washers, no washer , star washer under the locking nut, castle nut or what kind of nut for the 15 studs thru head?
Thanks, Bob
mark
10-19-2002 17:14:57
 Re: Y-91 flathead gasket ....copper coat it or not? in reply to Bob LaBrie, 10-19-2002 05:38:29
copper coat it if it is metal, If its not dont use anything. If you are talking about head studs use a SAE flat washer that is hardend (grade 8)
Bob LaBrie
10-20-2002 07:10:33
 Re: Re: Y-91 flathead gasket ....copper coat it or not? in reply to mark, 10-19-2002 17:14:57
It's metal on both sides with a composite material of some sort in between. One side hs lip round the cylinder hole. Can
t remember if lip goes up or down.
Regarding head studs. There are 15 and I wasn't sure whether to use flange nuts or washers.
Thanks for the advice. I couldn't find 3/8 24 Grade 8 flange nuts anyway at the HW store. I know they have SAE flat washers and nuts both in Grde 8.
Alberta Mike
10-20-2002 14:37:46
 Re: Re: Re: Y-91 flathead gasket ....copper coat it or not? in reply to Bob LaBrie, 10-20-2002 07:10:33
Aren't real head nuts somewhat longer from end to end than regular nuts? At least some of the tractors that I've worked on seem to have head nuts that seem long.
