Fuel gauge question
Brad in IN
10-22-2002 08:43:52
My fuel gauge is not working. I checked and found it has juice going to it. The ground seems to be okay also. How can I determine if the problem is a bad gauge, or a bad sending unit. Also, I pulled the light plugs from the gauges, and saw they never had bulbs installed. Anyone know why massey didn't do this? What is the bulb number for theses? Thanks for your help.
d3Mike
10-22-2002 15:50:43
 Re: fuel gauge question in reply to Brad in IN, 10-22-2002 08:43:52
Ground the wire that goes to the sending unit, the guage should go to full. If it doesn't, hit it hard while the sending unit wire is still grounded, the guages stick. If this fails, and you are sure the guage has power, then the guage is bad. If this works, but does not operate normal, then the sender body is not grounded or is bad. IF the tractor has been sitting a while,then fill the tank about half full and use the tractor, often this will clean the contacts in the sender. My 205 has the guages aluminated by a single bulb that sits above them, not multiple bulbs in each guage.
