Pushin' Snow with a 65?
Chip S.
01-26-2000 14:28:05
I have a newly restored MF 65 diesel that I am just having a ball with. Was wondering if any of you have ever used one to push snow, and what was the best set-up in terms of tire size, snow blade, chains, etc. If you made chains, how many feet of chain did you use? Are x-chains any better than regular? I have wheel weights, but I havn't filled the tires yet. Actually, it needs new tires, so I want to get something that'll work well in the summer and the winter.
I live in Maryland, so the most snow we get at one time is about 17".
Thanks
Tim (UT)
01-27-2000 12:35:11
 Re: Pushin' Snow with a 65? in reply to Chip S., 01-26-2000 14:28:05
If the snow is not too heavy, new tires will do as much as chains will. Last winter, my Ford 8N had old (almost worn down) rear tires and I needed chains if I was going to do anything with snow.
This winter - with brand new tires - the chains are still sitting on the shelf in the tool shed.
If you're going to get chains, I wouldn't make them up - just order them. I got a pair for my 8N (with 11.2x28 tires) for around $100 - mail order. Can't remember the name of the company, but it was some hardware store that had a good web presence - ordered them right off their web site.
Standard chains should be fine - either way, it's going to be a bumpy ride on frozen ground or cement.
As for a blade - you can either go front or rear. Rear blades are easy to come by and easy to put on/off - but they're not the greatest for places that get lots of snow. I use a rear blade on my 8N, but then I'm in the valleys of central Utah - we don't get much snow (that stays long). Also, a rear blade is easier to use when you have to clear away from buildings and such.
A front blade is nice when you have deep snow and a LONG place to plow. Like a 1/4 mile driveway or something.
Both front and rear blades can be angled (most of them...) so in both cases, you can plow snow to the side.
Tim
Ken
11-23-2000 12:11:27
 Re: Re: Pushin' Snow with a 65? in reply to Tim (UT), 01-27-2000 12:35:11
Tim, I had a 1956, 640 - Ford (600series) with a loader on the front, and a 6'6" 3-point grader on the rear. I live in a suburb of Chicago IL. area. I used this tractor for about 5yrs Plowing snow. This tractor has been used in my fathers construction bis. For as long as I can rember. Until one of my rear axel seals started to leak. It locked up my rear end, and ended up breaking gears in my trans. I now have 2-ford P/U trucks with Meyers 7'6" plows. Although I'm alot Warmer,and I'm working more with my trucks. I Miss the look on Childrens faces when I would pull up with my tractor all bundeled up the Kid in the Movie CHRISTMAS STORY to do there driveway. Some Kids would throw snow balls at me, Of course I'd throw some back at them, and other children would ask if I'd pile up the snow form there driveway to make a sleding hill.
So keep your oils up and take care of your 8n. You will miss it if it goes I Do.
Ken Rainit@hotmail.com
Chip
01-27-2000 06:52:38
Chip,
I was just out last night with my 35, I just use my rear blade. I have new tires, but no weights, it works pretty good on 7-8" of snow, a few passes and the drive was clear. When I get too much weight I just lift the blade slightly until I can move again.
Enjoy,
Chip
B.C.
01-27-2000 06:22:11
One solution is to build a rear plow out of 2 x 6's or equivalent. It wants to be a little wider than the outside width of the rear tires, and high enough to catch the top link of 3 pt hitch (say about 4 feet high). A couple of vertically mounted angle irons, stragetically drilled for the top link pin will do.
The 3pt drawbar is bolted to the lower middle of the thing. In this manner the 3 pt hitch arms both push and lift the blade. When the blade touches the ground the lift arms should be horizontal.
At least one stablizer link should be fitted to the lift arms to prevent sidesway.
Tire chains are highly recommended, but in a pinch they can be done without, especially for something the size of a 65. Cross link chains are fine.
A surplus grader blade, perhaps obtained from the county or some contractor, may be bolted to the bottom of the blade.
It can be used moving forward for clean up or light (1-2") snows but is most effective when used backing up.
It may not look elegant, but it sure will move snow.
