MH 44 GAUGES
BRUCE BARAGARY
11-02-2002 17:09:22
I would like to have three new gauges for a 44 massey harris gas any suggestions. I am also missing a 1949 tag under the battery area. It should be a show quality tractor when done. I have new paint, new steering wheel, new carb, new radiator tires and motor. Any suggestions would be greatly appreciated.
Alberta Mike
11-03-2002 12:07:25
 Re: MH 44 GAUGES in reply to BRUCE BARAGARY, 11-02-2002 17:09:22
I think David B is correct, Massey's didn't have Massey Harris on the gauges. They all seemed to be from the Rochester Gauge Company of New York if I remember correctly. Black-faced gauges with white letters/numbers I think.
David B
11-03-2002 06:01:04
Anderson Auto, Princton MN 763-386-4275 has good gauges for your tractor, you can buy individual or the set of three. They don't say Massey-Harris on them but I don't think the originals did either. For the serial number tag, Dan Whalen Amelia, OH 513-734-4040 will make you an original serial tag for the tractor or engine. Your serial number is stamped right below the pto shift lever on tob of transmission housing
