Pacer external oil lines why only 3/16
Bob LaBrie
11-04-2002 04:58:42
The original external oil lines were clogged on my Pacer. They are 3/16" and they go from oil pressure regulator gallery and splits to pressure gauge then up to external oil filer housing. The external oil filter housing then has 3/16" line at bottom and oil returns down to the block. My first impression is these lines are aweful small. I would imagine they are 3/16" by design. Going to 1/4" may affect internal oil pressure...maybe? I guess once the oil is hot it flows through 3/16 pretty easily. Any thoughts on this?
Thanks, Bob
Alberta Mike
11-05-2002 15:02:54
 Re: Pacer external oil lines why only 3/16 in reply to Bob LaBrie, 11-04-2002 04:58:42
The lines most likely plugged because somebody hadn't changed the oil in 50 years. If they're now clean and you've got fresh oil I'd suggest staying with what you've got. I imagine that pressure might drop if you went to a bigger size tubing line, didn't my highschool physics teacher tell me that once? Good luck with your project, that is a pretty rare little tractor.
