NEED SPECS ON THE 444 MH
STEVEN
11-08-2002 21:03:20
I am dead set on buying a couple of masseys down the road from where i live and would like to now abought the massey 444 as it is theone i would buy first, i now that it has a 277 motor in it and that it was produced for two years but i want hte horse power, if it came with live hydro and PTO, or just one. pulling cap, and if it has a torque converter. also while i am at it i guess that any info on a 44 diesel would be nice to. thanks in advance Steven H
marlowe
11-11-2002 15:13:50
 Re: NEED SPECS ON THE 444 MH in reply to STEVEN , 11-08-2002 21:03:20
they have both foot and hand clutch. the hand clutch is your live pto clutch it stop the forward movement of tractor so the pto runs push in the foot clutch all stops
STEVEN H
11-11-2002 21:22:29
 Re: Re: NEED SPECS ON THE 444 MH in reply to marlowe, 11-11-2002 15:13:50
is this the same one the m-h 44 as this could be usefull, my 44 needs a carb job and a new exaust manifold, oh yeah and thanks to that da%$ brake lock that are feet always seem to rest on, brakes before i can use it. know where i can get the gear pump and tank res for my 44 as i only have the control unit that is under the seat.
marlowe
11-10-2002 18:17:05
444 came with the 277 mine on the dyno. turns out 54 hp. 10 speed trans. the lever on the right is the live pto clutch lever its next to the right brake pedal and if you have a hyd. pump on the left side in front on the engine or p.s. you have live hyd.no torque converter. when we farmed it would pull 4-14 or 3-16 in a case trailer plow. only thing is to drive it and listen to the trans. in hi and low for noise ther is a top shaft that can get noisy
STEVEN H
11-10-2002 19:43:15
 Re: Re: NEED SPECS ON THE 444 MH in reply to marlowe , 11-10-2002 18:17:05
JUST me again, since i cant get any help on my other post what would you say a 444 standard in non runing condition is worth. it has been sitting for years, with fuel {so i think that is why it wont run}, looks good tin and paint wise, has hydraulics, good ruber but if i remember it is dry rot. also is under a roof with dirt floor, think all tires were inflated so rimes should be good.
STEVEN H
11-10-2002 19:31:30
thank you marlow, i am very greatfull for the info you have provided me with. from what i read the 444 has only a hand clutch, no??
i ask this only cause my 44 has a foot and hand clutch. also as far as tractors go hows this one rate? it sre loooks like a beast thats for sure.
444 owner buy the 444 if you can
11-11-2002 06:27:28
 Re: Re: Re: NEED SPECS ON THE 444 MH in reply to STEVEN H, 11-10-2002 19:31:30
Steven- some had a hand clutch as option. ours has a foot clutch. be sure the lovejoy is good. that connects the engine to the tranny. 444 is a super machine. in the condition you mentioned you can probably buy it reasonable. a restored unit will bring tall dollars, here about 4K or so. The standard version is not as valuable as a row crop to them fussy collector types, which I ain't.
steven h
11-11-2002 07:03:54
 Re: Re: Re: Re: NEED SPECS ON THE 444 MH in reply to 444 owner buy the 444 if you can, 11-11-2002 06:27:28
massey harris 444 here i come.
HEY MARLOWE? CAN YOU HELP THIS GUY?
11-10-2002 05:48:51
sorry fer shoutin- wanted to git Marlowes attention. He's got a 444 an will know a thing or 2 about your concerns/questions. I got a 444 too.
it ain't fer sale neither.
ray-s
11-09-2002 08:58:47
Steven , go to this site, Not all specs, but some for 44's
http://m-h.cs.uoguelph.ca/
C. T. in Oklahoma
11-10-2002 11:20:23
 Re: Re: NEED SPECS ON THE 444 MH in reply to ray-s, 11-09-2002 08:58:47
Steven, the site "m-h.cs.uoguelph.ca/" is correct. If you entered .com instead of .ca/, it takes you to a domain registering site. Just Use the copy/paste function and it will work. C. T.
STEVEN H
11-10-2002 11:56:20
 Re: Re: Re: NEED SPECS ON THE 444 MH in reply to C. T. in Oklahoma, 11-10-2002 11:20:23
SOME on the 44diesel but not anything that i didnt know as i was there and the massey 44 i own is almost the same but is gas. like i said i am more into the 444 as i need a biger tractor for are land the farmall H's i have have tolled me that the land is to much for them to even cut hay is some fields, as i lost two motors in this fashion
STEVEN H
11-09-2002 14:03:13
this site didnt work it sent me to a domain register page. post a link or maybe info thank steven h
