30 in first AGAIN
Eric
11-09-2002 13:39:47
hello i have been having troubles with my massey 30 getting stuck in first gear alot. My grandpa usualy came out and fixed it for me but he has past away and it is in gear. can anyone tell a youngster what to do?
Karl Hushaw
11-10-2002 15:33:00
 Re: 30 in first AGAIN in reply to Eric, 11-09-2002 13:39:47
As I grew up in a Massey dealership, sometimes the thing that happened was the end of the gearshift got worn, and when you shifted, it would not put the rail back to the centered position before you shifted to the next rail, therefore, you would be locked in a gear. The solution was to have the end of the gearshift built up by a welder, and ground back down to fit the rail.
MH Nut
11-10-2002 11:42:14
I have had the stacking problem when a tractor has some gear wear, and I have shifted gears while the tractor is rolling. The solution I have found is using a screw driver to realign the shifting rails. If I wait until the tractor has come to a complete stop before shifting I don't have the problem
C. T. in Oklahoma
11-10-2002 11:24:33
Try Big Deans's site "//hometown.aol.com/daustin62/Bigdeantipindex.html", page 2. The instructions were so good, even I could follow them. (twice). C. T.
Chris C.
11-09-2002 20:43:30
Its called "stacking the gears" a common Massey problem. If you unscrew the hyd/trans. filler plug next to the steering housing you can reach in with a screwdriver and slide it out of engagement if the gears are loaded you may have to jack the rear to unbind the tranny
Alberta Mike
11-10-2002 06:12:49
 Re: Re: 30 in first AGAIN in reply to Chris C., 11-09-2002 20:43:30
Any idea as to why this happens? I've got a couple of Masseys and it's never happened but I'd like to find out just in case it ever does. Might it be the shifting forks in the shift mechanism itself or is it something right in the tranny itself?
Eric
11-10-2002 07:46:30
 Re: Re: Re: 30 in first AGAIN in reply to Alberta Mike, 11-10-2002 06:12:49
thanks guys ill go out and try to get it out this afternoon... as to why it happens... it usualy happens when its under a big load which is why you would use first gear but then you cant get it out. My 22 has this same problem with with some hopping on the clutch and some pulling of the lever it will come out. how ever our 44 special never had a problem with this. the other times it has been stuck, is when i let other people drive it and since this tractors clutch isnt the best you have to hold down the clutch and waith a few seconds before you shift. if you try right away and just jamn it in there its hopeless to get out!
Jason
11-09-2002 17:55:00
Im a younger guy myself that likes to mess around with old tractors. Glad to see you getting involved!. Im no expert in the problem that you are having,but why not try blocking the rear wheels off the ground and have someone rock the wheels back and forth while you try to pull on the gear shifter. Just a thought. Hope every thing works out ok!
