165 Gas Died
Redneck in TN.
11-18-2002 19:55:55
My 165 Perkins gas burner died on me an will not crank back up. I've replaced coil, points, plugs, and cleaned out the carb. It will fire off like it's going to start then just spit an sputter and die. Any ideas what it could be. I was wondering if it could be the condenser.I have checked there is no water in gas. Thanks in advance.
Redneck in Tn.
11-22-2002 08:13:49
 Re: 165 Gas Died in reply to Redneck in TN., 11-18-2002 19:55:55
Hey every one I finally got the old red machine going. I had looked at the distributer cap several times, But I didn't see any thing wrong with it. Well guess what I finally changed it any way,Aaaaannndddd PUT,PUT,PUT away I went runs like a top. Thanks everyone for your help I appreciate it more than you know. Another satisfied customer. Hassel Ayers
Lloyd
11-22-2002 06:13:47
Redneck: what was the last thing it did when running well-retrace your steps from there,sounds like a simple fix, Good Luck-
Kent
11-22-2002 05:27:54
The 165 gas we have had this problem and it was the fuel shut off solenoid not staying on traced the wire and it had worked loose. Does yours have a fuel shut off solenoid? It was our problem.
marlowe
11-19-2002 09:58:14
check the timming!! might be bad cam gear or dist.gear or it might have just jumped time from loss dist.
Lynch
11-19-2002 05:14:37
Clogged vent in fuel cap?
Clogged fuel filter or screens?
restricted fuel line?
restricted carb?
needle valves need adjusting?
Air restricted?
Valves sticking?
Sounds like it's not getting fuel. Check carb for h2o? Lynch
