Rubber Boot Question
Bill
12-11-2002 09:11:48
I have replaced the rubber boots on the gear shift levers on my MF50, however, I need also to replace the rubber boot at the top link spring location under the seat. I've got the parts breakdown - but my question is - is this something you folks have done and how difficult is it?
Thanks in advance,
Bill
Doug
12-11-2002 15:13:51
 Re: Rubber Boot Question in reply to Bill, 12-11-2002 09:11:48
When I found that I needed to replace mine, I asked every Massey guy I could find. Every one of them told me not to attempt it. I was told that trying to get the big nut (which holds in the spring) out of the housing would surely result in cracking the housing. Plus, the boot is redundant as the entire spring housing is sealed to the inside. I don't use my tractor for plowing so don't need the draught control. Instead of the new rubber boot, I sealed the gap with silicone caulk.
David
12-11-2002 13:25:55
I did it recently but, admit to having taken a shortcut that is not very desireable but seemed a necessity at the time. First you remove the allen screw (hex socket head) on RHS of spring housing. That acts as a grub screw and when its loosened you should be able to turn the collar that holds the spring in. There is a special tool for this but mine turned quite easily with a hammer and a long punch. When its loose the whole spring assemble will lift out. Then you're supposed to drive out the pin that holds the clevis end (where the top link fits) to the shaft bit(I think!). Mine seemed unwilling to budge so I ended up carefully stretching the boot over the spring and fitting it that way. I did manage it but nicked the boot with a screwdriver that I was using to ease its passage over the tight bits. If it hadn't been for that it would have been ok as the stretching didn't seem to harm it in itself. It might depend on what quality of rubber boot you have though. Mine was a Vapormatic replacement part. It worked but for my carelessness but you do have to be prepared to risk ruining the boot trying it. I'd say if you can get the pin out do it the right way, but if not then its always an option.
eelke
12-16-2002 12:18:37
 Re: Re: Rubber Boot Question in reply to David, 12-11-2002 13:25:55
Check the drawing + text on the page I haved linked to this comment.
Can you tell me were i can buy such a rubber boot??
Jack in NB
12-12-2002 02:53:05
Tricky one!
David's removal procedure is good. The next step is unscrewing the yoke from the rod (MF calls it a control spring plunger, roughly 5/8 or 3/4 x 8" with a plate welded to the inner end to hold the spring) which runs through the centre of the spring.
And it's always siezed because water gets in the threaded hole in the yoke. Originally, a rubber plug was fitted to plug the hole to keep water out, but they all disappear. (We fill the hole with grease after reassembly.)
We hacksaw the rod about midway. You can then get the rod into a vise to hold it, drive out the 1/8" +/- roll pin in the yoke which keeps the rod from turning, heat the yoke, and unscrew it. Once removed, the threads may be cleanable and the rod welded back together.
If it buggers the threads in the yoke, they can be cleaned up with a tap. If the rod is too badly corroded or the threads shot, a new one is less than $30. aftermarket. (MF dealers might surprise us too. Sometimes their prices are actually below aftermarket!)
When reassembling, the rod threads should be coated with never-sieze, and tightened so the spring is snug, but can still be rotated by hand, and the rod turned to line up the end slots so a new roll pin can be installed. Coating the rest of the rod and spring with grease will reduce future corrosion.
