Mf 245 tach. problem
charles
12-22-2002 05:04:06
i have a mf model 245, 1979 year. the tachometer is not working because, apparently where the cable goes in the back is worn and is allowing the cable to slip, and nor turn the meter. can it be repaired. or should i look for replacement. thanks
Casey McDonald
12-28-2002 20:51:59
 Re: mf 245 tach. problem in reply to charles, 12-22-2002 05:04:06
If I were you I would just buy a replacement tachometer and cable. You can buy one at any MF dealer. Good Luck.
